Consolidating from hardware to iSeries/vCMP - Duplicate VLAN Names
We are in the process of consolidating 8 hardware devices down into 4 iSeries boxes running vCMP. I'm reading up about the new platform-migrate option introduced in 12.1.3. The challenge I believe I'm going to run into is all 8 hardware boxes have duplicate vlan names. Example: All 8 have lb-external and lb-ha VLANs. They also have an interface bundle called sync-failover-trunk. Has anyone dealt with this or have any suggestions on stragtegies to migrate our configuration.
Loading an archive using tmsh Migration to newer devices running software version 12.1.3, or later, ignores the following configuration objects. If your configuration includes dependencies on any of these objects, you must reconfigure them on the new device before you load the UCS file onto that device. Important: You must reconfigure the following objects on the new target device to use the same names as the objects on the source device before you load the UCS file onto that device Interfaces, Interface bundles, Management IP address, Management route
