Connection Mirroring issue - Serverside Connection Information Missing on Standby
Hello,
I am running 2 x Viprion 2400 Chassis each with a single B2250 blade (Version 11.5.1 HF10). I have a vCMP guest on each chassis which are setup as Active/Standby and using OSPF for routing. All appears to be working well (i.e. OSPF, Virtual Servers) except for the connection mirroring feature. Under connection mirroring I have selected "Between Clusters" and have the HA VLAN as the primary mirror address and Internal VLAN as the secondary mirror address.
The issue is the connection mirroring only works approximately 50% of the time. When it doesn't work, the mirrored connections will appear on the standby unit without any serverside connection information and it will not be removed until the idle timer reaches 300+ seconds, even if the client has terminated the connection. Below is an example taken from the standby unit. I connected to an HTTP virtual server which is setup for connection mirroring 12 times.....it fails to register any serverside connection information 5 times and those 5 will remain for 300+ seconds.
Standby
user@(adc-mgmt)(cfg-sync In Sync)(/S1-green-P:Standby)(/Common)(tmos) show sys conn | grep a.a.160.207
a.a.160.207:59873 b.b.7.10:80 any6.any any6.any tcp 0 (slot/tmm: 1/0) none
a.a.160.207:59875 b.b.7.10:80 b.b.7.11:59875 b.b.60.10:80 tcp 4 (slot/tmm: 1/0) none
a.a.160.207:59873 b.b.7.10:80 any6.any any6.any tcp 4 (slot/tmm: 1/0) none
a.a.160.207:59873 b.b.7.10:80 any6.any any6.any tcp 11 (slot/tmm: 1/0) none
a.a.160.207:59877 b.b.7.10:80 any6.any any6.any tcp 1 (slot/tmm: 1/0) none
a.a.160.207:59879 b.b.7.10:80 b.b.7.11:59879 b.b.60.10:80 tcp 4 (slot/tmm: 1/0) none
a.a.160.207:59873 b.b.7.10:80 any6.any any6.any tcp 19 (slot/tmm: 1/0) none
a.a.160.207:59877 b.b.7.10:80 any6.any any6.any tcp 4 (slot/tmm: 1/0) none
a.a.160.207:59873 b.b.7.10:80 any6.any any6.any tcp 27 (slot/tmm: 1/0) none
a.a.160.207:59877 b.b.7.10:80 any6.any any6.any tcp 12 (slot/tmm: 1/0) none
a.a.160.207:59881 b.b.7.10:80 any6.any any6.any tcp 1 (slot/tmm: 1/0) none
a.a.160.207:59884 b.b.7.10:80 any6.any any6.any tcp 1 (slot/tmm: 1/0) none
a.a.160.207:59873 b.b.7.10:80 any6.any any6.any tcp 34 (slot/tmm: 1/0) none
a.a.160.207:59877 b.b.7.10:80 any6.any any6.any tcp 19 (slot/tmm: 1/0) none
a.a.160.207:59881 b.b.7.10:80 any6.any any6.any tcp 5 (slot/tmm: 1/0) none
a.a.160.207:59884 b.b.7.10:80 any6.any any6.any tcp 4 (slot/tmm: 1/0) none
a.a.160.207:59873 b.b.7.10:80 any6.any any6.any tcp 41 (slot/tmm: 1/0) none
a.a.160.207:59886 b.b.7.10:80 b.b.7.11:59886 b.b.60.10:80 tcp 3 (slot/tmm: 1/0) none
a.a.160.207:59877 b.b.7.10:80 any6.any any6.any tcp 26 (slot/tmm: 1/0) none
a.a.160.207:59881 b.b.7.10:80 any6.any any6.any tcp 12 (slot/tmm: 1/0) none
a.a.160.207:59884 b.b.7.10:80 any6.any any6.any tcp 11 (slot/tmm: 1/0) none
a.a.160.207:59888 b.b.7.10:80 b.b.7.11:59888 b.b.60.10:80 tcp 3 (slot/tmm: 1/0) none
a.a.160.207:59873 b.b.7.10:80 any6.any any6.any tcp 48 (slot/tmm: 1/0) none
a.a.160.207:59877 b.b.7.10:80 any6.any any6.any tcp 33 (slot/tmm: 1/0) none
a.a.160.207:59881 b.b.7.10:80 any6.any any6.any tcp 19 (slot/tmm: 1/0) none
a.a.160.207:59884 b.b.7.10:80 any6.any any6.any tcp 23 (slot/tmm: 1/0) none
a.a.160.207:59891 b.b.7.10:80 b.b.7.11:59891 b.b.60.10:80 tcp 4 (slot/tmm: 1/0) none
a.a.160.207:59873 b.b.7.10:80 any6.any any6.any tcp 60 (slot/tmm: 1/0) none
a.a.160.207:59877 b.b.7.10:80 any6.any any6.any tcp 45 (slot/tmm: 1/0) none
a.a.160.207:59881 b.b.7.10:80 any6.any any6.any tcp 31 (slot/tmm: 1/0) none
a.a.160.207:59884 b.b.7.10:80 any6.any any6.any tcp 34 (slot/tmm: 1/0) none
a.a.160.207:59873 b.b.7.10:80 any6.any any6.any tcp 71 (slot/tmm: 1/0) none
a.a.160.207:59877 b.b.7.10:80 any6.any any6.any tcp 56 (slot/tmm: 1/0) none
a.a.160.207:59881 b.b.7.10:80 any6.any any6.any tcp 42 (slot/tmm: 1/0) none
a.a.160.207:59894 b.b.7.10:80 b.b.7.11:59894 b.b.60.10:80 tcp 4 (slot/tmm: 1/0) none
a.a.160.207:59884 b.b.7.10:80 any6.any any6.any tcp 46 (slot/tmm: 1/0) none
a.a.160.207:59897 b.b.7.10:80 b.b.7.11:59897 b.b.60.10:80 tcp 5 (slot/tmm: 1/0) none
a.a.160.207:59873 b.b.7.10:80 any6.any any6.any tcp 83 (slot/tmm: 1/0) none
a.a.160.207:59877 b.b.7.10:80 any6.any any6.any tcp 68 (slot/tmm: 1/0) none
a.a.160.207:59881 b.b.7.10:80 any6.any any6.any tcp 54 (slot/tmm: 1/0) none
a.a.160.207:59884 b.b.7.10:80 any6.any any6.any tcp 58 (slot/tmm: 1/0) none
a.a.160.207:59900 b.b.7.10:80 any6.any any6.any tcp 1 (slot/tmm: 1/0) none
a.a.160.207:59873 b.b.7.10:80 any6.any any6.any tcp 95 (slot/tmm: 1/0) none
a.a.160.207:59877 b.b.7.10:80 any6.any any6.any tcp 80 (slot/tmm: 1/0) none
a.a.160.207:59881 b.b.7.10:80 any6.any any6.any tcp 66 (slot/tmm: 1/0) none
Any assistance would be appreciated.
