Technical Forum
Connection Limit , Connection Rate Limit in virtual server
THE_BLUE
Cirrus
Cirrus
what is the recommended Connection Limit , Connection Rate Limit in virtual server which will helps detect Denial of Service attacks?
5 REPLIES 5
Samir
MVP
MVP
Connection Rate Limit is best option to protect DOS/DDOS attacks. I will prefer this method.
yes, but there are many mode which one is the best. on other words , how to choose the mode based on what ?
I have applied iRule[Connection Rate Limit ] based on expert advice. So far we are good. Let see if any one had different ideas?
Could you please share with us the irule you have used?
please refer this.. It will help you..
https://support.f5.com/csp/article/K07150625
https://devcentral.f5.com/s/articles/virtual-server-connection-rate-limit-with-tables
