Technical Forum
Custom Alert Banner
Connecting to F5 using SSH via Ansible
AHS
I am in the process of writing a playbook which uses SSH to connect to F5 and run a bash command (ntpdate -d time_server) to confirm NTP connectivity across the environment. For SSH I am using root. Here is the task that I have in the playbook.
- name: "Check NTP on {{override_host}}"
  vars:
     ansible_connection: ssh
     ansible_user: "root"
     ansible_password: "{{root_pwd}}"
     ansible_ssh_private_key_file: "~/.ssh/f5-ansible-ssh"
  command:
  cmd: ntpdate -d {{item}}
  loop: "{{new_ntp_servers}}"
  register: ntp_status
 The error message that I get is as follows
MSG:
The module failed to execute correctly, you probably need to set the interpreter.
See stdout/stderr for the exact error
MODULE_STDOUT:
/bin/sh: /usr/local/bin/python3.9: No such file or directory
MODULE_STDERR:
******************************* IMPORTANT NOTE ******************************
Banner
Shared connection to ltm closed.
Any help would be greatly appreciated...
3 REPLIES 3
Paulius
MVP
MVP
@AHS This doesn't seem to be specific to F5 but to Ansible itself. The following article seems to have a similar issue and it revolves around the Ansible server not knowing the path for python3.9. If you read through the article it could help you get back on track.
https://github.com/IBM/ansible-for-i/issues/84
@Paulius -- Apologies for the late reply. I was tied up with another engagement. Thank you for the suggestion. I did see that git-hub post & did try the stuff mentioned there before posting here.  Unfortunately, it did not help. The issue started happening after I upgraded the f5-collections. I rolled back the f5-collections to 1.22, but that still did not fix the issue.  I donot think the issue was with the collections itself but a combination of collection, ansible & python version. To get this working again, I had to create a virtual environment & use that for ansible. Here are the steps
mkdir ~/tmp
mv ~/.ansible ~/tmp
mv ~/.cache ~/tmp
mv ~/.config ~/tmp
mkdir -p ~/workspace/venv
cd ~/workspace/venv
/usr/local/bin/python3.9 -m venv ./ansible-2.9.17
Wait for the virtual environment to get created
source ~/workspace/venv/ansible-2.9.17/bin/activate
pip install --upgrade pip
pip list
This should show you default packages with pip
pip install ansible==2.9.17
pip install paramiko
pip list
ansible-galaxy collection install -r requirements.yml
The requirements file is as follows
collections:
  # --- F5 Collections ---
  - name: f5networks.f5_modules
    version: 1.22.0
  - name: f5networks.f5_bigip
  # --- Required for clean STDOUT ---
  - name: ansible.posix
  # --- Required for IP management ---
  - name: ansible.utils
  # --- Required for json_query ---
  - name: community.general
I also switched to paramiko for ssh connectivity instead of ansible's built in module.
Leslie_Hubertus
Community Manager
Community Manager
Hi @AHS - did the link @Paulius shared help? If yes, please click the Accept as Solution button so future users with the same issue can easily find resolution.
