Technical Forum
configure SSL certificate with order manager
Silver_back
Altostratus
Altostratus
I am writing a script to configure an SSL certificate with the certificate order manager, however, I am having trouble getting the right syntax. Does any know the CLI command to configure an SSL certificate with the certificate order manager?
tmsh modify sys crypto crs cert-order-manager Certificate_authority key key-size 2048
Am assuming it would be something like the above.
1 REPLY 1
Hello Silver_back.
Try with "create" instead.
Regards,
Dario.
