Technical Forum
Custom Alert Banner
Configure F5 to do asymmetric tráffic
The_Problem
HI everyone
I need help with one configuration, I have a VS receiving the traffic with one pool member and automap enable, until this everything is great, but now we have a new route on the network, the problem is that we need to receive the traffic for the route A and send the response of that traffic using the route B, basicaly is to do a asymmetric connection, The backend server are not using the f5 like DGW for that the automap is enable, only the response had to be rerouted to the new route B.
How this can be posible?. Thanks for the help.
4 REPLIES 4
Have you seen the article below? Also see nPath routing:
https://support.f5.com/csp/article/K13558
https://support.f5.com/csp/article/K11116
Also if you have some HTTP manipulation or Advanced WAF /APM this may not work.
https://support.f5.com/csp/article/K01155812
https://support.f5.com/csp/article/K02949801
T-Trust
MVP
MVP
Hi
So i think you can find information from this link : f5-big-ip-asymmetric-traffic
Heath_Parrott
F5 Employee
F5 Employee
Please see what @Nikoolayy1  shared about nPath routing if the response packet is not returnd back to the LTM system.  If the packet IS returning to the LTM system but on a different VLAN then you will need to look into VLAN keyed connections - https://support.f5.com/csp/article/K13558
If you managed to get the needed answers, please flag the question as answered.
