Configure balancing with XMPP protocol
Hello.
I would like to know if someone has performed a balancing with XMPP using an irule so that it reads the "TO" of the message and is sent to a specific node of the associated POOL.
A similar example would be to perform an irule so that when it reads a code from the HTTP header, it is sent to a specific node:
log local0. "client IP: [IP::client_addr] - [virtual] - [whereis [IP::client_addr] country]"
switch -glob [IP::client_addr] {
"190.50.130.0/18"
switch -glob [HTTP::header values identificadorDIS] {
"PRD_001_TX1" {
# Proyect Test
log local0. "Entra a PRD_001_TX1"
# SSL::disable serverside
pool pool_pay member 10.16.50.10 8020
"PRD_001_TX2" {
log local0. "Entra a PRD_001_TX2"
pool pool_pay member 10.16.50.11 8020
default {
log local0. "PDV invalido: [HTTP::header values identificadorDIS] "
reject
default {
log local0. "IP no permitida: client IP: [IP::client_addr] - [virtual] - [whereis [IP::client_addr] country]"
reject
...But with the XMPP protocol
Thank's
