Configuration transfer from TMOS 9.X.X to 11.X.X
Techgeeeg_28888
Hi Everyone,
I have a LTM box running TMOS ver. 9.x.x which will be upgraded to TMOS 11.1 with latest hot-fix I have a problem with the configuration transfer. M i going to loose all the configuration and have to redo it? or there is a way to transfer the information from old platform to the new platform kindly help.
Regards,
1 REPLY 1
nitass
F5 Employee
F5 Employee
did you follow the upgrade path recommendation?
sol13845: Overview of the supported BIG-IP upgrade paths and upgrade planning reference
http://support.f5.com/kb/en-us/solutions/public/13000/800/sol13845.html
about configuration transfer, have you tried "/usr/libexec/bigpipe daol"? it would show an error which prevents configuration to be loaded.
