Compare between LTM Full feature and LTM basic in AWAF?
kridsana
Hi
Anyone have a list of comparision features between LTM Full feature and LTM basic in AWAF?
I want to know what is remove from LTM Full features. So I'll know if just AWAF license is enough for me or I need to buy LTM+AWAF
Thank you
1 ACCEPTED SOLUTION
Hi kridsana,
K14231234: Comparing F5 Advanced WAF and BIG-IP ASM profiles and features
https://support.f5.com/csp/article/K14231234
1 REPLY 1
Hi kridsana,
