Technical Forum
Custom Alert Banner
Communication between DMZ & Internal devices
mahjoub
Cirrus
Cirrus
I'm going for upgrading my system on coming weekend, as it's first time to do that, I have one concern need your support.
I have 4 VM machines, 2 in DMZ and 2 internal, I will start upgrading DMZ standby device then the active one, for the internal machines I'll keep it for next week end.
my question, is there will be any problems in communication between DMZ machines and Internal, or in Apps functions because after successful upgrading both will be in different version.
thanks in advance.
1 ACCEPTED SOLUTION
AlexBCT
MVP
MVP
Hi Mahjoub,
Short answer; probably not.
Long answer; probably not, but... 😉
What versions of software are you going from/to? The smaller the jump, the less likely that there are any behaviour changes or unexpected communication issues. And what modules are you using? Only LTM, or any other ones as well? And are the two DMZ systems in any way clustered with the internal systems? I suspect not, and that they are two separate clusters, but if you do have all 4 of them in one big cluster, a bit more caution is needed (though still not a big problem).
Also, are you using BigIP DNS (formerly known as GTM)? If so, and you are using iQuery for the communication between the systems, keep an eye on that as well.
An idea to help you get a bit more confidence with the upgraded system before fully committing to it; after upgrading the standby member, keep an eye on its monitors (assuming you are monitoring most of the internal resources from the DMZ cluster). These should all be reporting as Green again (all good) and if you are happy that everything looks good, you can fail over to this newly upgraded system. Rather than directly upgrading the second DMZ system, you can keep running on this newly upgraded system for a day or so and fail back to the not-yet upgraded system if you do come across any issues. You can then even reboot back into the old partition of the upgraded system to be completely back to the beginning.
Please be aware though that if you are running different versions within a cluster, you do not have stateful failover and should not be making any config changes during that time.
By the way, have you seen F5's upgrade document? https://support.f5.com/csp/article/K84205182 It's a really helpful tool to run through and doublecheck that you haven't forgotten anything. It also helps you make sure you follow best-practise during the upgrade process.
Hope this helps.
2 REPLIES 2
AlexBCT
MVP
MVP
Hi Mahjoub,
Hope this helps.
mahjoub
Cirrus
Cirrus
Hi Alex,
thanks for your reply,
we have two modules LTM and APM only, no GTM and iQuery as well,
I will upgrade from v12 to v14
I hope these answers can help you.
in the last, many thanks for your valuable advices and the great link which you shared, really appreciated 🙏
