Technical Forum
client direct connect to pool member
neeeewbie
MVP
MVP
Hi guys
I need your help !
ex architecture) pool member gateway is F5 internal self IP //
does the pool member session increasing when client direct connect to pool member and reply packet forwarding external through forwarding virtual server
so, this situation pool member session increase on F5 session table ??
thank you
1 ACCEPTED SOLUTION
Connections count under pool will get increment in only case when request will come to Virtual server and VS will forward it to the pool. If client is trying to connect to directly pool member, that will be separate connection all together which will not make any changes under Pool statistics. Also if web server is initiating request towards internet which is going via F5, this will also create separate connection via F5 but no change in pool statistics.
Connections made directly to web servers or web server initiating traffic towards external services maintains separate connections and can be see under cli using - show sys connection
Pool statistics will get incremented only when there is request on VS and VS forwarding it to Pool.
Hope it helps!
Mayur
1 REPLY 1
Hope it helps!
Mayur
