Vladimir_Shishk's avatar
Vladimir_Shishk
Jul 07, 2021
Client cert auth and TLS1.3
Good day.
I have a SSL-site with enabled Client Cert Auth (Client cerificate request, frequency once).
I'm trying to get access to this site with PKI-card via Mozilla and Chrome.
When I enable TLS1.3 (option "no TLSv1.3" in client ssl-profile is disabled), I receive only a certificate request, but don't get a PIN prompt and then have an
ERR_SSL_CLIENT_AUTH_NO_COMMON_ALGORITHMS error.
: Connection error: ssl_hs_rx_tls13_cert:3672: alert(46) no certificate
When I disable TLS1.3 (option no TLSv1.3 is enabled), I receive a certificate request, then enter PIN and after I have an access to web-site via TLS1.2.
What should I do to have an TLS1.3 access to this site?
Thank you.
  • Hi,
    what does the /var/log/ltm say when the connexion error appears ?
    Regards
    • Vladimir_Shishk's avatar
      Vladimir_Shishk
      Jul 7 14:59:40 host1 warning tmm[20902]: 01260009:4: client1%1:1029 -> server1%1:443: Connection error: ssl_codec_rx:2314: alert(46) received alert
      Jul 7 14:59:40 host1 warning tmm[20902]: 01260013:4: SSL Handshake failed for TCP client1%1:1029 -> server1%1:443
      Jul 7 14:59:43 host1 warning tmm3[20902]: 01260009:4: client1%1:32621 -> server1%1:443: Connection error: ssl_codec_rx:2314: alert(46) received alert
      Jul 7 14:59:43 host1 warning tmm3[20902]: 01260013:4: SSL Handshake failed for TCP client1%1:32621 -> server1%1:443
      Jul 7 14:59:44 host1 warning tmm[20902]: 01260013:4: SSL Handshake failed for TCP client1%1:8457 -> server1%1:443
      Jul 7 14:59:46 host1 warning tmm2[20902]: 01260009:4: client1%1:4606 -> server1%1:443: Connection error: ssl_codec_rx:2314: alert(40) received alert
      Jul 7 14:59:46 host1 warning tmm2[20902]: 01260013:4: SSL Handshake failed for TCP client1%1:4606 -> server1%1:443
      Jul 7 15:00:21 host1 warning tmm1[20902]: 01260009:4: client1%1:33624 -> server1%1:443: Connection error: ssl_codec_rx:2314: alert(42) received alert
      Jul 7 15:00:21 host1 warning tmm1[20902]: 01260013:4: SSL Handshake failed for TCP client1%1:33624 -> server1%1:443
      Jul 7 15:00:28 host1 warning tmm[20902]: 01260009:4: client1%1:1036 -> server1%1:443: Connection error: ssl_codec_rx:2314: alert(80) received alert
      Jul 7 15:00:28 host1 warning tmm[20902]: 01260013:4: SSL Handshake failed for TCP client1%1:1036 -> server1%1:443
  • RicFer's avatar
    RicFer
    Hi , have you found a solution to this issue ?
    We are having similar issues with client authentication working with TSL1.2 but partially with TLS1.3.
    Based on the ltm logs we see:
    Connection error: ssl_shim_vfycerterr:4202: alert(46) application verification failure.
    Connection error: ssl_hs_rx_tls13_cert:3726: alert(46) no certificate.
    Any help / hint would be appreciated.
  • Hi. I am experiencing the same problem.
    How can I solve this problem?
    And why is this log displayed after enable the TLSv1.3?
    Thank you
