JG's avatar
JG
Oct 16, 2015
Citrix XenApp with APM: How to set SSLProxyHost?
APM (re-)writes the launch.ica file, and within it, sets SSLProxyHost to be the name of the virtual server.
I have a weird, and challenging, case in which I need to set SSLProxyHost to be a different server. However, this does not seem to be manually configurable.
I tried an irule, but the HTTP_RESPONSE event does not capture the response for this file.
Any help is appreciated.
  • Not sure on the detail but would expect you need to use HTTP_RESPONSE_DATA event to capture the ica file and manipulate it. Useing HTTP::collect and HTTP::payload might help you.
  • JG's avatar
    JG
    I have got the solution from F5 support, and it turned out that the "remote desktop" was automatically configured to use the virtual server as the proxy, and we needed to customise this config:
    Step 1:
    Access Policy  ››  Application Access : Remote Desktops : Remote Desktops List  ››  "name_of_my_remote_desktop"
    Step 2:
    In the field "Custom Parameters",  add:
        ProxyType=Auto
