Michael_Saleem's avatar
Mar 13, 2019
Cipher Rules and Groups (v14.1.0.2)
Has anyone noticed any issues with
cipher rules
and
cipher groups
in v14.1.0.2?
For example, in the user comments from the following article, it was mentioned that on v13, when making a modification to cipher rules that the changes did not propagate (from my testing on v14.1.0.2, this issue appears to have been fixed)
https://devcentral.f5.com/articles/cipher-rules-and-groups-in-big-ip-v13-25200
From what I understand, the use of a cipher group is required for TLS1.3 (client side). You cannot specify a cipher suite string on the client SSL profile when you have TLS1.3 enabled. Is this correct?
  • Hi Michael,
    haven't played with TLS1.3 on 14.1. yet, but it would make me wonder if you can't use a tailordered cipher suite string in combination with TLS1.3 anymore.
    Take a look to K10251520 (click me) to get the latest information regarding TLS1.3 support. The article outlines the steps required to enable TLS1.3 on a SSL profile as well as the TLS1.3 related Cipher String values
    TLS13-AES128-GCM-SHA256
    TLS13-AES256-GCM-SHA384
    and
    TLS13-CHACHA20-POLY1305-SHA256
     tmm --clientciphers ALL | grep TLS13
    Cheers, Kai
