01-Apr-2022 07:00
I'm having a hard time finding a recent K article that indicates the character limit on object names for the BIG-IP. We're in the process of re-evaulating naming conventions and the only article I can find was this one but not sure this still holds true with the newer versions. Does anyone have a more recent article?
https://support.f5.com/csp/article/K14440
Solved! Go to Solution.
02-Apr-2022 01:32
Hello,
I try to test in the lab, I would like to sent the sult that i test on major version 13.x.x that found limit 255 characters
Please find the result in my lab in link below,
https://cloud-ttrust.com/f5-virtual-server-and-pools-name-limited-to-255-characters/
Thanks you
01-Apr-2022 08:44
This is only article exits under KB. If you will add more then 255charscter then below error will appear.
0107141f:3: The maximum allowable length of 255 for a full path has been exceeded.
01-Apr-2022 09:10
Yeah, I saw that error in the article but wasn't sure if I was missing a new article.
02-Apr-2022 01:32
Hello,
Thanks you
