Ben_Wilson_2412
Jul 11, 2013Cirrus
Changing HTTP Reponse status code
I've been asked to change the reponse HTTP Status code for custom 404 pages to "404" instead of 200.
It looks like this is possible by checking if the request is for /404.jsp, capturing the payload with HTTP::Payload and the using HTTP::Response to generate a new response with the captured payload.
Is there an easier way?
I'm concerned about capturing all the payload response on the F5. There could be thousands of 404 and I'm afraid of running the device out of memeory. Is that a valid concern?
Thanks!
Ben
