Change active volume for next boot.
deh_21598
Hello.
I need that curently active partition will be active for next reboot. How can I do this without rebooting device?
Screenshots attached.
1 ACCEPTED SOLUTION
nitass_89166
Noctilucent
Noctilucent
welcome. actually, i just realized it works in v11 as well. 😛
sol5658: Overview of the switchboot utility
http://support.f5.com/kb/en-us/solutions/public/5000/600/sol5658.html
please be noted that it will reboot automatically in viprion platform.
sol9296: Changing the default boot image location on VIPRION platforms forces a reboot to the new boot location
http://support.f5.com/kb/en-us/solutions/public/9000/200/sol9296.html
7 REPLIES 7
nitass
F5 Employee
F5 Employee
have you tried switchboot command?
deh_21598
tnx a lot!
did't know about that command.
nitass
F5 Employee
F5 Employee
Worked for me too. BIG-IP Virtual Edition 11.6.1. Thanks!
nitass_89166
Noctilucent
Noctilucent
Mark_Ellis_3300
I had an issue where my VE lab would not shutdown and reload into a newly installed software image through the normal "activate" function. A bit more manual, but the switchboot command worked for me too. Thanks! v12.0.0 --> v12.1.3
