Technical Forum
Can we run curl in tmsh mode ?
Sarovani
Cirrocumulus
Cirrocumulus
Hi Experts ,
Can we run curl command in tmsh mode ?
<tmos>curl -vk https://10.10.10.1
or do we have any option to use <bash> along with tmsh and execute the curl in tmos ?
3 REPLIES 3
boneyard
MVP
MVP
depending on your rights you can do
run util bash
to end up in bash
i don't believe you can do things like what you ask from tmsh
DenisG
F5 Employee
F5 Employee
Anything is possible with the f5 (Doesnt mean you always should tho)
From within tmsh shell use this:
run /util bash -c 'curl -vk https://f5.com'
CA_Valli
MVP
MVP
Access to the advanced shell is restricted to users within certain roles.
The TMSH does not allow to run bash commands. Call bash shell with command "bash" for that.
Refer to the tech docs for more information about user roles and advanced shell: https://techdocs.f5.com/en-us/bigip-15-0-0/big-ip-systems-user-account-administration/user-roles.html#GUID-9C4946A7-21EA-41A1-A42E-BED65CAB0576
