Technical Forum
Can't delete 'path' inside a partition
jtrotz1
I am trying to learn to use FAST, but first starting with AS3.  Starting with "Quick Start" https://clouddocs.f5.com/products/extensions/f5-appsvcs-extension/latest/userguide/quick-start.html
I ran the example, which worked fine.  When I look in the GUI I see it created LTM objects in partition/path "/Sample_01/A1".
However, I wanted to clean up what it created by deleting all the objects using the GUI (vSever, pool, nodes, etc). When I tried to delete the partition "Sample_01" I get an error saying its not empty. I don't see anything with "A1" either.
I looked in the file system using a bash shell /config/partitions/Sample_01 and don't see anything.
In TMSH I can cd to /Sample_01 and also to /Sample_01/A1/. When I list ltm I don't see much.
I grep'd all the files in the /config folder and don't see any refereences to a an "A1" 'path'.
Any suggestions how to deleted all this stuff that got created using AS3?
Thanks,
-Jim
1 REPLY 1
Mithilesh_Kuma1
