cwkim_261931's avatar
cwkim_261931
Mar 29, 2017
Can not reset connections statistics(virtual servers, pools current/max/total statistics)
I saw that connections statistics count is 76M(current, max, total is same 76M).
And I reset statistics.
Bits and Packet statistics is cleared.... But connections statistics is not cleared...
I try to reset statistics at GUI and CLI.
I think that data(statistics) is not true.(76M is too high for operating system and backend system.)
So I think that connection buffer is overflow, and connections statistics is not properly checked and reset.
Have you ever been this case? And How do you solve it? except reboot...
And I want to know the location of stored connections statistics.
Plz help me....
OS version is 11.6.1 HF1 Platform is BIG-IP 10000s
  • Did you try running "show sys connection" to identify the existing connections ?
