Technical Forum
Can I run TMSH commands inside an iRule?
mahanth
Altostratus
Altostratus
I have added:
set NODENAME [HTTP::header value test]
 POOLMEMBER_IP=($(tmsh list ltm node $NODENAME | grep "address" | awk '{print $2}'))
1) I am trying to run tmsh commands using/in iRule
2) Trying to get just the Node IP from Node Name
9 REPLIES 9
Hello Mahanth.
I think you are mixing concepts. Take into account this:
  • TMSH are management plane scripts
  • iRule are dataplane scripts.
So, you cannot access a F5 config using iRule commands.
One idea that you could use is to resolv your server hostname using your DNS.
[lindex [RESOLV::lookup $hostname] 0]
REF - https://clouddocs.f5.com/api/irules/resolv__lookup.html
Regards,
Dario.
Regards,
Dario.
Please note that with v15 RESOLV::lookup is deprecated and no longer supported!
https://clouddocs.f5.com/api/irules/RESOLVER__name_lookup.html
https://clouddocs.f5.com/api/irules/DNSMSG__record.html
Regards,
Dario.
which just includes that it can no longer be written nicely on one line...or 2...or 3... 🙂
JRahm
Community Manager
Community Manager
deprecated just means it is marked for removal in a future version. As long as it's still available it will be supported.
Trust me, with v15 you dont want to use that anymore, unless you are ready for core dumps....
I guess you mean this:
https://cdn.f5.com/product/bugtracker/ID916753.html
It's a problem with the object name resolution, but it has workaround.
Regards,
Dario.
Yeah, thats the one we raised. And it has a workaround but its not so easy to implement depending on the environment you have, since we have a complete custom dev cycle for irules. But, well.
JRahm
Community Manager
Community Manager
Ok fair enough, Rene! 😃
But generally, deprecated doesn't mean immediate death sentence. Test, test, then test some more, and as I recommend with any new release, comb the release notes and if there is a better way forward with any implementation, iterate through those updates as resources allows.
