neeeewbie's avatar
Mar 31, 2020
Solved
Can I display ssl handshake fail reason using irule?
Hi guys I need your help
I have list of ssl handshake failure alert but I don't know how to define alert using irule
ex) 40 is The sender was unable to negotiate an acceptable set of security parameters given the options available.
please let me know if you know way
thank you
