19-Mar-2020 22:18
Hi guys
I want to block syn flooding using irule
So, my plan is counting syn flooding base of source and destination IP
set src and dst and set max-request and time
but I don't know how to count syn ..
Let me know it if you know how to count syn packet
thank you
Solved! Go to Solution.
20-Mar-2020 11:11
Hello.
There exists an iRule event that you can use to count TCP Sync packets
https://clouddocs.f5networks.net/api/irules/FLOW_INIT.html
Don't forget to test it in lab before moving to production.
This event has some bugs that could make you crash your TMM.
KR,
Dario.
20-Mar-2020 11:11
Hello.
KR,
Dario.
20-Mar-2020 11:13
You can't do it - syn cookies do a better job and if you have a standard VS then it will take care of it anyway because it is a full proxy ie it will only create a server-side connection when the client-side connection is setup. You can also look at dos profiles with AFM and possibly ASM.
