02-Mar-2023 23:31
Hello Team.
Can someone advise please if there is any chance bug (https://cdn.f5.com/product/bugtracker/ID969097.html) will be fixed in a newer version?
Many thanks in advance,
Best regards,
Oleksandr
05-Mar-2023 23:37
If you hav not already done: Best is to open a ticket and ask to attach it to this bug id and inform your partner manager.
20-Mar-2023 22:51
Hi Oleksandr,
Did you get an answer on this? The Bug document only mentions 15.1.x releases as affected. Unsure if this is accurate, but could mean it's not an issue in v16?
21-Mar-2023 12:40
Hi AP,
Interesting question. When I asked if this bug would be fixed in a newer version, a TAC engineer said that it would definitely be fixed, however BugIDs are managed by the F5 Product Development top management and unfortunatelly they do not share any detail regarding the schedule.
As a workaround, the implementation of Layered virtual server solution was proposed. (https://my.f5.com/manage/s/article/K03113285)
If you will have a proper answer to your question, please share it also with me.
Thank you in advance,
BR,
Oleksandr
28-Mar-2023 00:03
No, I don't have any new information. It's a bit vague in the documentation, however I agree that it sounds like it won't be an issue in v16.
Regards.
12-Apr-2023 01:59
Hi AP,
I received a confirmation that this bug is still not fixed in any BIG-IP version and it does not have a high priority at the moment. So I can assume that it will not be fixed soon.
BR,
Oleksandr
12-Apr-2023 18:30
Hi Oleksandr,
Thanks for the update. Appreciate it! Good to know.
Regards,
AP
