John_McCulloch's avatar
John_McCulloch
Jul 01, 2021
Blocked 'Reverse Connections'
Hi all,
Recently we have ran into an issue with connections that involved our BIGIP devices and client server connections when there is a firewall as man in middle. The issue that is seen presents itself as a reverse connection i.e. ports flipped or source = 443 that gets blocked. Furthermore, this issue does not seem to stem from one set of client or servers devices and also seems to happen with health checks.
Now rules have been put into place on the MIM firewall that allow for the expected flow of traffic and this issue does not seem to be service affecting but it does generate a mass of logging for the blocks. I have attempted troubleshot what I can only describe as half closed behaviour but unfortunately have started to come up dry with further theory's as to why the F5 does not seem to tear down the connection along with the rest of the devices and sends one last packet that gets blocked when the other side closes the connection forcing the firewall to remove it from its state table.
My hope is that others may have experienced this or can add to the conversation so I can look into other avenues for investigation.
  • Maybe it is not the same but I had issue that the F5 and the servers may have different time_wait for connection reuse as for f5 is 2 seconds by default and you may change this for the newer tcp profiles to match the servers as their time_wait could be bigger or smaller (for windows servers it is much bigger):
    https://support.f5.com/csp/article/K29377715
    For fastl4 there is still no such option and adding a SNAT pool with many ip addresses and maybe preserve the source port for SNAT:
    https://support.f5.com/csp/article/K14400019
    Also randomizing the ports helps but this are system variables, so be carefull:
    https://support.f5.com/csp/article/K8246
    https://support.f5.com/csp/article/K46113533
  • Thanks for the response, unfortunately we are not using fastl4.
    In regards to the TIME_WAIT, I did look down this path and they do seem to have a longer setting compared to the F5. Interestingly it does seem to be the F5 client side of the VS's that are having the issues, servers side seems to close 4 way without as many issues.
    I have noticed that the F5s are responding to the FIN's sent with double ACKS. The client generally seems to be responding to this with a RST closing one half of the connection. I will look further into the KA's above and see if there is anything else I have missed though.
    Just a quick addition for clarification, these reverse connection are not new connections they seem to be the tail end of already existing/closing connections.
  • Ok great, I will have a further look into that then report back if it helps. Thanks again for the support.
