AlexS_yb's avatar
AlexS_yb
Oct 17, 2021
BIGIQ & Letsencrypt
Hi
Any one create an irule to handle the api landing for challenges ?
I can do manually
I was thinking irule should be able to handle
grab the info store it locally ? with time out
then when request comes through look up value and send
so
1) how to write irule to get post data
2) how to store locally - APM session isn't the place so where is ?
  • So it seems like the BIGIQ doesn't actually do any magic ,, it talk to the lets encrypt servers
    it utilised an API interface into a back end.
    so for any one googling to here.
    I have my VS and I have a backend pool - nginx on rhel
    for location /.well-known/acme-challenge/
    I send to the nginx pool
    on nginx i have this
     location /.well-known/acme-challenge/ {
      root   /var/www/html/uatwww.yieldbroker.com;
      index   index.html index.htm index.php;
      add_header Last-Modified $date_gmt;
      add_header Cache-Control 'no-store, no-cache, must-revalidate, proxy-revalidate, max-age=0';
      if_modified_since off;
      expires off;
      etag off;
      location /.well-known/acme-challenge/api {
       #index   index.html index.htm index.php;
       perl f5acme::handler;
    and the perl code is this
    package f5acme;
    # this is to be the end point
    use nginx;
    use JSON::Parse 'parse_json','assert_valid_json';
    sub handler {
     my $r = shift;
     if ($r->request_method ne "POST") {
      return DECLINED;
     if ($r->has_request_body(\&post)) {
      return OK;
     return HTTP_BAD_REQUEST;
    sub post {
     my $r = shift;
     $r->send_http_header;
     eval {
      assert_valid_json ($r->request_body);
     if ($@){
      $r->print("Your JSON was invalid: $@\n");
      $r->status(406);
      return;
     my $js = parse_json ($r->request_body);
     my $fname="/var/www/html/uatwww.yieldbroker.com/.well-known/acme-challenge/".$js->{'challenges'}[0]{'fileName'};
     unless ( open FILE, '>'.$fname ){
      $r->print("unable to create $fname\n");
      $r->status(406);
      return;
    seems to work , try at your own risk :)
