Jim_M's avatar
Jim_M
Icon for Cirrus rankCirrus
Aug 12, 2020
BigIP v14 single volume - adding a volume
I have previously updated software on LTMs. However, the virtual F5 i am working on now only has one disk volume. Is there a different method to install software on a single volume system? if not, how would i add a new volume? In the web interface, i see no options under software volumes or disk volumes to add a new one.
  • Thanks for that. I did not realise that the system would create a specified volume if it does not already exist. I have now confirmed that it does just that.
    • nishantramsumar's avatar
      nishantramsumar
      Hi
      Does the VE appliance remain active when creating & installing the TMOS as is on the physical with more than 1 volume?
