Technical Forum
BIGIP UPGRADE
THE_BLUE
What are the main differences between BIGIP versions 15, 16, and 17 ? What is the current recommended and stable version to upgrade to?
1 ACCEPTED SOLUTION
Hello,
Usually, the most stable version in each software release is the latest one which contains all of the fixes on that major software version.
For example, here is the list of the most stable versions in each major release, which are the latest releases:
version 15: 15.1.7
version 16: 16.1.3
for version 17, it is the base version only that is released.
Regarding the differencies between major versions with respect to the features, you can check the release notes for each version you are looking forward to upgrade to:
Version 15.1.7:
https://techdocs.f5.com/kb/en-us/products/big-ip_ltm/releasenotes/related/relnote-supplement-bigip-1...
Version 16.1.3:
Version 17.0.0:
https://techdocs.f5.com/en-us/bigip-17-0-0/big-ip-release-notes/big-ip-general.html
https://techdocs.f5.com/en-us/bigip-17-0-0/big-ip-release-notes/big-ip-new-features.html
Or if you are looking for an exact feature, you can simply check in which version it is published and then select this version.
BR,
Mohamed Salah
3 REPLIES 3
Hello,
version 15: 15.1.7
version 16: 16.1.3
Version 15.1.7:
Version 16.1.3:
Version 17.0.0:
BR,
Mohamed Salah
Hoang_Hung
Cirrus
Cirrus
I think it will current recommended. But you can follow F5 vulnerabilities , from it you can use it for upgrade .
https://support.f5.com/csp/article/K55879220
https://support.f5.com/csp/article/K30425568
LiefZimmerman
Community Manager
Community Manager
@THE_BLUE - If @Hoang_Hung and/or @Mohamed_Salah_ provided the information you were looking for please select *Accept As Solution* on their reply (or both). This helps future readers find answers more quickly and confirms the efforts of those who helped.
Thanks for being part of our community.
Lief
