10-Dec-2021 00:53
Hi Guys,
To make a backup, I use the ansible module for F5 "bigip_ucs_fetch".
I would like to add a passphrase to my ucs file. For that I use the option "encryption_password" on my playbook.
The problem is that even if I use this option, the file is not encrypted.
Has anyone ever had the same problem or woulf have an idea for a solution? Is it a bug?
Thank you
