05-Mar-2020 21:29
06-Mar-2020 04:19
When you use single NIC deployment, then all traffic shares single NIC means both management and Data traffic will be on same NIC whereas with multiple NIC, you can separate your management, data, and internal traffic so that each has its own NIC. Single NIC deployment is quite simple architecture but it limits overall throughput as you will have one NIC only which will handle all the traffic.
Hope it helps you!
Mayur
