Technical Forum
BigIP Client - Error: 1761
Joachim082
Hello,
I have problems with cached credentials object on my windows 10 host using local profiles. The Logfile says:
"CStandaloneDoc::OnNewSession, Failed to query credentials from service. Error: 1761 (0x6e1) Die entry wasn't found"
We have this problem since using FSLogix-Profiles on our environment. Has anybody an idea what the problem could be?
Best Regards,
Joachim
1 REPLY 1
Joachim082
Hi, no update from support on that topic? What is the reason for that message? BR
