SolarJeans's avatar
Nov 22, 2022
Solved
BIGIP BIND for CVE-2022-38177
Hello Expert,
My BIGIP are vulnerable by CVE-2022-38177 and we would like to apply the work around as stated in KB
disable-algorithms "." {
        "ECDSAP256SHA256";
        "ECDSAP384SHA384";
From KB, it said all modules are impacted. So if I do not provision DNS module, how can I disable these algorithms in BIND?
  • If you don't have BIG-IP DNS provisioned then BIND should not be provisioned for end-user access.
    If it is enabled then you can use the ZoneRunner interface to make the modification to the configuration. https://support.f5.com/csp/article/K6963
    I believe DNS Cache/DNS Express don't rely on BIND (they are built into TMM) so should not be vulnerable to this issue.
  • Hi SolarJeans,
    You are referring t this F5 article am I right
    BIND vulnerability CVE-2022-38177 (f5.com)
    there are 2 workaround told
    Recommended Actions
    If you are running a version listed in the Versions known to be vulnerable column, you can eliminate this vulnerability by installing a version listed in the Fixes introduced in column. If the Fixes introduced in column does not list a version for your branch, then no update candidate currently exists for that branch and F5 recommends upgrading to a version with the fix (refer to the table).
    If the Fixes introduced in column lists a version prior to the one you are running, in the same branch, then your version should have the fix.
    Upgrade the OS version to not Vulnerable
    the one which you are talking is a mitigation but you never know if your OS version is still open and containing other vulnerabilities.
    hence in order to decide can you please share your OS version .
    • SolarJeans's avatar
      SolarJeans
      Icon for Cirrus rankCirrus
      Hello F5_Design_Engineer
      My version is 15.1.6 so there is no patch which can fix it.
      And we would like to do mitigation in this situation, which is disabled the algorithms.
      • Hi SolarJeans ,
        For 15.1.x OS version following ciphers will get impacted , see the last column for 256 or 384
        when you will disable
                "ECDSAP256SHA256";
                "ECDSAP384SHA384";
        If any of the keys using these CIPHERS will cause error till the key validation time not expired based on ttl.
        https://support.f5.com/csp/article/K86554600
        ECDHE-ECDSA-AES128-GCM-SHA256 (0xc02b)128TLS1.2ECDHEECDSAAES-GCMSHA256
        ECDHE-ECDSA-AES128-SHA (0xc009)128TLS1, TLS1.1, TLS1.2ECDHEECDSAAESSHA
        ECDHE-ECDSA-AES128-SHA256 (0xc023)128TLS1.2ECDHEECDSAAESSHA256
        ECDHE-ECDSA-AES256-GCM-SHA384 (0xc02c)256TLS1.2ECDHEECDSAAES-GCMSHA384
        ECDHE-ECDSA-AES256-SHA (0xc00a)256TLS1, TLS1.1, TLS1.2ECDHEECDSAAESSHA
        ECDHE-ECDSA-AES256-SHA384 (0xc024)256TLS1.2ECDHEECDSAAESSHA384
        ECDHE-ECDSA-CHACHA20-POLY1305-SHA256 (0xcca9)256TLS1.2ECDHEECDSACHACHA20-POLY1305NULL
        ECDH-ECDSA-AES128-GCM-SHA256 (0xc02d)128TLS1.2ECDHECDSAAES-GCMSHA256
        ECDH-ECDSA-AES128-SHA (0xc004)128TLS1, TLS1.1, TLS1.2ECDHECDSAAESSHA
        ECDH-ECDSA-AES128-SHA256 (0xc025)128TLS1.2ECDHECDSAAESSHA256
        ECDH-ECDSA-AES256-GCM-SHA384 (0xc02e)256TLS1.2ECDHECDSAAES-GCMSHA384
        ECDH-ECDSA-AES256-SHA (0xc005)256TLS1, TLS1.1, TLS1.2ECDHECDSAAESSHA
        ECDH-ECDSA-AES256-SHA384 (0xc026)256TLS1.2ECDHECDSAAESSHA384
        You can refer
        K55150974: ECDSA algorithm is currently not supported for DNSSEC in DNS cache
        https://support.f5.com/csp/article/K55150974
        https://support.f5.com/csp/article/K54424313
        you can also refer
        Zone Signing Key
        Navigate to: DNS ›› Delivery : Keys : DNSSEC Key List
        https://f5-agility-labs-dns.readthedocs.io/en/repo_cleanup/class2/module4/lab1.html
        You can also see
        signature-valid-period
