Albert_Coll's avatar
May 10, 2021
Solved
BIG-IQ reports capabilities and licensing.
I'm just newbie in the BIG-IQ solution, so apologize in advance for this question if too easy.
I've just deployed a BIG-IQ VM in a VMware farm, only with the F5-BIQ-VE-LAB License Management for 25 Devices.
With it, I can add my two existing BIG-IP LTM and perform the configuration management of both.
I have no Data Collection Device deployed since for that, I assume I must get a license that uses the SKU: F5-BIQ-VE-LOG-NODE.
My problem is that with my current deployment, I cannot obtain almost any report at all.
Should I buy a LOG license and deploy a DCD to get reporting capabilities?
Best regards.
Albert.
  • Hi Albert,
    Yes and no...
    Yes, you need to have a DCD for the logging capabilies, but no, you don't need to buy a license for it. For a few years, the F5-BIQ-VE-LOG-NODE license was a zero-cost license; after F5 recognised that nobody wants to buy BigIQ licenses purely for a log node, it was a kind of placeholder to make it work.
    Since version 7.1, the license is no longer needed either, and you can build a DCD node without a license. When building the DCD, in the initial wizard, simply select skip or "no license" and you can continue.
    Hope this helps.
  • Hi Albert,
    Yes and no...
    Hope this helps.
