BIG IP SSL Default Certificate
Ajeet_Gupta
The self signed default certificate in my BIG IPs are about to expire and some are already expired. As I see default certificates are attached with some SSL profiles. Do we really required to renew these default certificates in BIG IP. What will cause if we don't renew these certificates.
Thank You
Regards
Ajeet Gupta
1 REPLY 1
Grumpy_Cat
Cirrus
Cirrus
Hi Ajeet
Same for all certificate expiration; you'll lose vs functionality when the SSL certs are invalid/expired.
To renew you can follow this article (ensure you take a ucs as advised in the article):
https://support.f5.com/csp/article/K13579
Kind regards
Ben
