dum0785
Aug 05, 2020Cirrus
Solved
BIG-IP send gratuitous ARP when force standby?
I want you to tell me.
Does BIG-IP send gratuitous ARP when the active unit is forcibly switched back to the standby state after a failover? (ex. run sys failover standby)
Also, can I check the log to see if gratuitous ARP has been sent?
Thank you and best regards,
stanby member no, but the unit becoming active will send GARPs .
