Technical Forum
BIG-IP : irule class match with wildcards
BaltoStar_12467
F5 BIG-IP Virtual Edition v11.4.1 (Build 635.0) LTM on ESXi
Can [class match] be used to match its arg against a list of strings containing wildcards ?
[class match [string tolower [HTTP::path]] contains whitelist]
whitelist data-group
"/default.html" "/desert-dwellers/camel.html" "/amphibians/*" "/kids-favorites-*" "/smelly/goat-*-juvenile"
So all of the following paths would match positive against whitelist :
`"default.html" "/desert-dwellers/camel.html" "/amphibians/platypus.html" "/kids-favorites-1.html" "/kids-favorites-2.html" "/smelly/goat-billy-juvenile" "/smelly/goat-nanny-juvenile"
If [class match] data-group does not support wildcards is there another syntax possible - such as partial-matching ( left-to-right ) of any entry in the data-group ?
9 REPLIES 9
nitass
F5 Employee
F5 Employee
i do not think so.
anyway, since you are using contains, why don't you remove asterisk in the data group?
"/default.html" "/desert-dwellers/camel.html" "/amphibians/" "/kids-favorites-"
thanks nitass yes that works for data-group list items i posted - but what about "/smelly/goat-*-juvenile" or similar mid-match ?
you are right. mid-match won't work. there is no simple solution yet.
nitass_89166
Noctilucent
Noctilucent
i do not think so.
Samir_Jha_52506
Noctilucent
Noctilucent
i do not think you need asterisk (*) in data group since you are using class match. Can you please try this.
"/default.html" "/desert-dwellers/camel.html" "/amphibians/platypus.html" "/kids-favorites-1.html" "/kids-favorites-2.html"
iRule
when HTTP_REQUEST { if { [matchclass [HTTP::uri] starts_with whitelist] } { HTTP::redirect "http://www.xyz.com" } }
Greg_Chew_31149
Historic F5 Account
for left to right match, could "starts with" work instead of "contains"? https://devcentral.f5.com/wiki/iRules.class.ashx
Stan_Ward
Altocumulus
Altocumulus
This is an old thread, but I've encountered a similar requirement, and am considering the following.: doing a search on the data-group and iterating over the entire list. The keys would be RegEx match strings and the values would be RegEx translation strings. It means that the RegEx compare of the source URL must happen against each returned search item using a RegEx compare. It loses the benefit of the more efficient list searching of class, but still allows storing the match and translation entries in a data-group with any conceivable match or translation rule.
The use case is a generic redirector with 1500+ entries, some of which have strange mapping requirements, i.e.
*.domainA.com/[path1 | path2 ]/index.jsp -> *.domainB.com/path3/index.jsp
*.domainA.com/*/index.jsp -> *.domainB.com/*/index.jsp
where both the hostname and the path have mappings to be done, and we can't enumerate all the possible combinations as explicit rules (we literally don't know what values are legal). Ugly, but not very high volume; mostly used for situations where we acquired a domain and the old function has been split in to two new destinations; we expect them to bookmark the new URL once they are there.
Most of the rules are not nearly that complicated, so perhaps it could be two data groups, one for the 95% case that can do a normal class match ''starts_with' or 'contains', and if that doesn't hit, search the second one for the ugly stuff. The value can be a RegEx translation string in either case; it's the wildcard source that is the problem.
