Technical Forum
BIG-IP edge Client, Bluescreen on Win10
Alcora_326045
Hello
Everytime i use Edge Client, my windows crashes. When i start up programs, Softphone, Outlook, IE, Chrome, Skype and AD, it gets blue screen and shuts down. After the 4th or 5th time, it seems like it stops. When im not using BIG-IP edge client, everything works fine.
Ive attached a picture of the Bluescreen. Can anybody help me with a solution for this? 🙂
1 REPLY 1
Matt_Dierick
F5 Employee
F5 Employee
Please raise a case with F5 support for investigations. You could try with the EDGE client in the market and the Fat Edge Client. Just to compare the behaviour.
