BIG-IP DNS SNI monitoring
We are trying to get a SNI monitor to work on a BIG-IP DNS to a generic host. Using the external ADFS monitors the checks fail. When running a CURL to the destination servers we receive Unknown SSL protocol error in connection while a openssl test returns the cert and the CN we are grepping for but the moniotr still fails.
We have tried with the standard ADFS external monitor provided by F5 along with the amended version for TLS1.1 and above. Also tried another custom one from Devcentral. Can anyone provide any pointers in how we could get this to work?
Monitor 1:
!/bin/sh These arguments supplied automatically for all external monitors: $1 = IP (nnn.nnn.nnn.nnn notation) $2 = port (decimal, host byte order) This script expects the following Name/Value pairs: HOST = the host name of the SNI-enabled site URI = the URI to request RECV = the expected response Remove IPv6/IPv4 compatibility prefix (LTM passes addresses in IPv6 format)NODE=
echo ${1} | sed 's/::ffff://'
if [[ $NODE =~ ^[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}$ ]]; then
NODE=${NODE}
else
NODE=[${NODE}]
fi
PORT=${2}
PIDFILE="/var/run/basename ${0}
.sni_monitor_${HOST}_${PORT}_${NODE}.pid"
if [ -f $PIDFILE ]
then
echo "EAV exceeded runtime needed to kill ${HOST}:${PORT}:${NODE}" | logger -p local0.error
kill -9 cat $PIDFILE
> /dev/null 2>&1
fi
echo "$$" > $PIDFILE
(echo -e "GET $URI HTTP/1.1\r\nHost: $HOST\r\nConnection: Close\r\n\r\n"; sleep 2) | openssl s_client -cipher 'ECDHE-RSA-AES256-SHA' -servername '$HOST'
STATUS=$?
rm -f $PIDFILE
if [ $STATUS -eq 0 ]
then
echo "UP"
fi
exit
Monitor 2
NODE=${NODE}
else
NODE=[${NODE}]
fi
PORT=${2}
if [ -f $PIDFILE ]
then
> /dev/null 2>&1
fi
curl-apd -k -i --resolve $HOST:$PORT:$NODE https://$HOST$URI | grep -i "${RECV}" > /dev/null 2>&1
STATUS=$?
rm -f $PIDFILE
then
echo "UP"
fi
exit
Monitor 3
!/bin/bashpidfile="/var/run/$MONITOR_NAME.$1..$2.pid"
if [ -f $pidfile ] then kill -9 -
cat $pidfile
> /dev/null 2>&1
fi
echo "$$" > $pidfile
node_ip=
echo $1 |sed 's/::ffff://'
node_port=$2
getscript () { echo 'GET / HTTP/1.1' echo 'Host: ..*.com' echo '' while sleep 0; do echo 'quit\n' done }
docurl () { IFS=$'\n' arr=($(getscript | openssl s_client -connect ...:443 -servername ...com 2>/dev/nul |grep -E CN=...com)) unset IFS }
docurl
echo ${arr[0]}if [ -n "${arr[0]}" ] then Remove the pidfile before the script echoes anything to stdout and is killed by bigd rm -f $pidfile echo "up" fi
Remove the pidfile before the script endsrm -f $pidfile
