Technical Forum
BIG-IP AFM DoS Device Protection source IPs logged?
hosting-team
Are the source IPs of a DoS attack logged on the F5 anywhere?
2 REPLIES 2
hosting-team
Vector: TCP bad ACK flood
Trigger: Volumetric, Aggregated across all SrcIP's, Device-Wide attack, metric:PPS
Mitigation: Blocked
We see this but would the source IPs have been logged?
The KB shows IPs in a packtet capture during a DoS but I assume that is not turned on by default.
AubreyKingF5
Community Manager
Community Manager
Logging on a DoS firewall needs to be carefully dialed in. If we were to turn on source logging by default, a 3DoS could fill a BIG-IP disk in minutes, or even seconds, depending on the attack. Unfortunately, the answer to your question is 'No,' however.. I would highly encourage you to get a dedicated physical link on your F5 - as big as you can get it.. maybe 2 ports per box, aggregated - for logging, if you want to do DoS logging.   Then, you need to set up a logging profile:
https://support.f5.com/csp/article/K51266926
That should be enough to point you in the right direction.
