15-Oct-2020 00:56
Is there any functionality to conditionally announce directly connected networks similarly to how you can use a route-map to conditionally announce a default route or how you can use RHI to conditionally announce kernel-routes?
My goal is to only announce connected routes on the active unit, but using
redistribute connected
announces the connected networks on all devices, while
redistribute connected route-map conditionalRoutemap
doesn't work (ie. the networks are not announced anywhere).
19-Oct-2020 08:55
Hello Mandragor.
Try to configure it with "in/out" parameter.
You can also try with neighbor field instead.
REF - https://support.f5.com/csp/article/K10095057
Regards,
Dario.
19-Oct-2020 23:22
Thank you for your suggestion, but my issue is not to filter which connected networks to announce but on which device - I want to ensure that the connected networks are only announced on the active device, and by using neighbor route-map or prefix-list I still announce any matched network on the standby device as well, unfortunately.
20-Oct-2020 01:02
Hello Mandragor.
Your syntax should be fine.
redistribute [connected|isis|kernel|ospf|rip|static] route-map WORD
The issue could be in how your "conditionalRoutemap" is configured.
Could you share it?
Regards,
Dario.
21-Oct-2020 08:24
Hello Mandragor.
I was checking some production environment with BGP on it and it hasn't got any specific configuration for active and standby units. Actually, I would bet that BGP is not advertising any route in standby unit by default.
Have you validated this somehow? (traffic-capture, show ip route at PE,...)
Regards,
Dario.
