Technical Forum
Custom Alert Banner
Best way to pass http header by iRule containing Client TLS information
Moinul_Rony
Altostratus
Altostratus
Hi All,
We are planning to identify TLS connection information from clients. ie: TLS version, CIPHER suits
How can we trap and pass through this client information via HTTP header so application team can analyse.
Thanks.
1 ACCEPTED SOLUTION
Hi Moinul_Rony,
	HTTP::header insert X-Forwarded-TLSVersion [SSL::cipher version]
	HTTP::header insert X-Forwarded-CipherName [SSL::cipher name]
	HTTP::header insert X-Forwarded-CipherBits [SSL::cipher bits]
3 REPLIES 3
Hi Moinul_Rony,
Thansk @Enes_Afsin_Al ,
Do you happen to have the full list of [SSL::Options?
SSL::cipher name
SSL::cipher version
SSL::cipher bits
These are the values that can be used for SSL::cipher.
https://clouddocs.f5.com/api/irules/SSL__cipher.html
You can view all SSL:: commands from the link.
https://clouddocs.f5.com/api/irules/SSL.html
