29-Oct-2015 04:53
Looking for the best method (iRule, HTTP Class, etc) to rewrite URI while preserving the trailing data in the URI and ensuring that no client redirect occurs. I also need to insert a header in the mix of all this.
Client request - https://www.site.com/123
F5 Rewrite - Request - https://www.site.com/123 to https://www.site.com/321 Insert Header SetContextURI: http://www.site.com/123
F5 Rewrite - Response - https://www.site.com/321/blah/data (Preserve Data) to https://www.site.com/123/Blah/data
I have looked at several options, but none bring both the Request, Response, and header insert together or will do a client redirect.
29-Oct-2015 07:26
Try adding the default stream profile and using and iRule like this:
HTTP::header insert "SetContextURI" "http://[HTTP::host][HTTP::path]"
HTTP::path [string map {/123 /321/PRServlet} [HTTP::path]]
Disable the stream filter for all requests
STREAM::disable
LTM does not uncompress response content, so if the server has compression enabled
and it cannot be disabled on the server, we can prevent the server from
sending a compressed response by removing the compression offerings from the client
HTTP::header remove "Accept-Encoding"
when HTTP_RESPONSE {
STREAM::expression {@/321/PRServlet@/123@}
Enable the stream filter for this response only
STREAM::enable
re-write Location header
HTTP::header replace Location [string map {/321/PRServlet /123} [HTTP::header Location]]
29-Oct-2015 12:16
Brad, Thank you for the response. I believe this is going to work. I'm curious was a piece missing for the http:// to https:// ?
when HTTP_RESPONSE { Replace http:// with https:// STREAM::expression {@/321/@/123/@}
16-Dec-2015 07:43
Brad, I apologize for the delay. We were not able to test this as the systems were Production. We bought a set of Dev-QA F5 VEs, deployed them, and are testing this solution. Unfortunately things aren't working as we'd hoped. In doing packet captures the request is getting re-written but sending a 303 back to the requesting application server which causes an error. Let me see if I can update what I see as the task our Dev/Middleware team is trying to accomplish.
16-Dec-2015 08:50
Hey Brad, Thank you for the response! So I applied the irule to site2. The 303 is coming from the server and is not being re-written on the outbound portion of the irule. Also the user indicated he had to add hit /123/ vs just /123, so modified the rule slightly.
So in the packet capture I see /123 come in and being re-written to /321, but I don't see the reciprocal.
Current iRule: when HTTP_REQUEST { HTTP::header insert "SetContextURI" "http://[HTTP::host][HTTP::path]" HTTP::path [string map {/123 /321/PRServlet} [HTTP::path]] Disable the stream filter for all requests STREAM::disable LTM does not uncompress response content, so if the server has compression enabled and it cannot be disabled on the server, we can prevent the server from sending a compressed response by removing the compression offerings from the client HTTP::header remove "Accept-Encoding" } when HTTP_RESPONSE { STREAM::expression {@/321/PRServlet@/123@} Enable the stream filter for this response only STREAM::enable }
Samples from the packet capture External - Original Request GET /123/ HTTP/1.1\r\n
Internal - What was sent to the server GET /321/PRServlet/ HTTP/1.1\r\n
Internal - Response from the server */!STANDARD?
External - Response sent to the requesting device */!STANDARD?
External - Next request from the requesting device GET /321/PRServlet/-j04puREN5KesgWh7fQGTaX18YQyXIPY*/!STANDARD? HTTP/1.1\r\n
Internal - What was sent to the server GET /321/PRServlet/-j04puREN5KesgWh7fQGTaX18YQyXIPY*/!STANDARD? HTTP/1.1\r\n
16-Dec-2015 11:05
ltm virtual VS_Site2-8050 { destination 10.1.1.3:8050 ip-protocol tcp mask 255.255.255.255 partition Surround pool Pool-Site2-IAC-SSO-App-8050 profiles { /Common/http { } /Common/stream { } tcp-lan-optimized { } } rules { Site2-IAC-URI-Rewrite-IRULE Site2-WebSphere-JSESSIONID-Persist-iRule } source 0.0.0.0/0 source-address-translation { pool Site2-IAC-SSO-SnatPool type snat } vs-index 10 }
