Blue_whale's avatar
Blue_whale
Jul 24, 2022
Backend nodes goes unreachable from active F5
Hi Team ,
We are facing node reachability issue from Active f5 on evryweeknd (sunday ) but this happens only from the Active F5 and for few VIP/pools only ..
We simply failover the f5 to standby and issue resolves and then failback to standby ..
Has anyone faced such issue ? We have virtual appliance configured on the ESXi host .
Before opening a TAC case , Can anyone confirm if you have faced similar problem ?
I did not find anything on the audit logs which indicates some sceduled jobs running at tht time ..What else can be checked ?
  • Emad's avatar
    Emad
    We had a similar issue. It was resolved after disabling Proxy ARP at gateway firewalls.
    • Blue_whale's avatar
      Blue_whale
      But this happens for only few pool emebers and only on the weekend at 11:00 am CET .
    • boneyard's avatar
      boneyard
      Icon for MVP rankMVP
      if it is that predictable you should run a packet capture on the big-ip and one of the servers. you will probably see the traffic stop and arps not being answered. that is what to focus on next, where does it get lost.
        Blue_whale
        On F5 I am getting reset packet from backend server but I don't think its server who is sending the reset packet ... Because on standby f5 we do have issue .
