Thanushka_Wije1's avatar
Thanushka_Wije1
Jun 19, 2019
Automated F5 LTM pre and post checks
Hi
I'm trying to automate F5 check using F5sdk, unfortunately I think that sdk retrieve virtual server details via .conf file.
Reason I'm telling that is from sdk I'm unable to retrieve F5 Availability.
Below is the script I'm using to print virtual server names,
from f5.bigip import ManagementRoot
# Connect to the BigIP
hostname = input("Please Enter F5 IP: ")
mgmt = ManagementRoot(hostname, "admin", "admin")
# Get a list of all pools on the BigIP and print their names and Availability
virtuals = mgmt.tm.ltm.virtuals.get_collection()
for virtuals in virtuals:
   print(virtuals.name, virtuals.partition)
Anyone know how can I get availability status using F5 sdk ?
  • Hello Thanushka.
    Try this ->
    devices = session.tm.cm.devices.get_collection()
    for device in devices:
    	print("Device: {}".format(device.name))
    	print("State: {}".format(device.failoverState))
    Output:
    Device: bigip1.mydomain.local
    State: active
    Device: bigip2.mydomain.local
    State: standby
    KR,
    Dario.
  • Hi Dario
    Thanks for the responses, but this will return device HA status not the virtual server (Availability). status..
    • Dario_Garrido's avatar
      Dario_Garrido
      Icon for Noctilucent rankNoctilucent
      The availability of a virtual server resides in the stats
      from f5.utils.responses.handlers import Stats
      session = ManagementRoot("F5_mgmt_IP","username","password",token=True)
      virtual = session.tm.ltm.virtuals.virtual.load(name='testVS')
      #https://<F5_mgmt_IP>/mgmt/tm/ltm/virtual/testVS
      virtualstats = Stats(virtual.stats.load())
      #https://<F5_mgmt_IP>/mgmt/tm/ltm/virtual/testVS/stats
      for key, value in virtualstats.stat.items():
          if value.get('description') != None:
              print("{}: {}".format(key, value.get('description')))
          elif value.get('value') != None:
              print("{}: {}".format(key, value.get('value')))
      KR,
      Dario.
  • JG's avatar
    JG
    for virtual in virtuals:
        if hasattr(virtual, 'subPath'):
            subp = virtual.subPath
        else:
            subp = ""
        if (subp != ""):
            print("Name: '%s' AvailabilityState: '%s'" % (virtual.name, get_vs_state(virtual.name, subp)))
        else:
            print("Name: '%s' AvailabilityState: '%s'" % (virtual.name, get_vs_state(virtual.name, "")))
