15-Sep-2020 06:12
Hi All,
Has anyone tested the Vulnerability Assessments Integration with QRadar VA using Generic Scanners?
QVM gives out a .xml file but unfortunately is not able to use our generic schema to generate the .xml
I have tried to convert it using few tools but am not able to get a working file that gets accepted by our ASM.
Any Ideas?
Regards !!
