03-Oct-2020 14:04
Anyone here faced the issue that "ASM_REQUEST_BLOCKING" not being triggered in LTM iRule ?
The "Trigger ASM iRule Events Mode" is set to normal in ASM policy
Running v15.1.0.5
New setup, never tried this before ..
Solved! Go to Solution.
26-Oct-2020 11:35
I believe it found the issue, as this is a response violation (it is not something bad send by the client, but the response the webserver sends is what should be blocked) it should be handled in the ASM_RESPONSE_VIOLATION event.
this iRule both logs the violation and allows me to rewrite the block page.
when ASM_RESPONSE_VIOLATION {
log local0. "response violation"
set x [ASM::violation_data]
for {set i 0} { $i < 7 } {incr i} {
switch $i {
0 { log local0. "violation=[lindex $x $i]" }
1 { log local0. "support_id=[lindex $x $i]" }
2 { log local0. "web_application=[lindex $x $i]" }
3 { log local0. "severity=[lindex $x $i]" }
4 { log local0. "source_ip=[lindex $x $i]" }
5 { log local0. "attack_type=[lindex $x $i]" }
6 { log local0. "request_status=[lindex $x $i]" }
ASM::payload replace 0 [ASM::payload length] ""
ASM::payload replace 0 0 "12345607890"
HTTP::header replace Content-Length [ASM::payload length]
logs
Oct 26 19:32:00 bigip-01 info tmm[20840]: Rule /Common/irule-asm_blockpage <ASM_RESPONSE_VIOLATION>: response violation
Oct 26 19:32:00 bigip-01 info tmm[20840]: Rule /Common/irule-asm_blockpage <ASM_RESPONSE_VIOLATION>: violation=VIOLATION_REDIRECT
Oct 26 19:32:00 bigip-01 info tmm[20840]: Rule /Common/irule-asm_blockpage <ASM_RESPONSE_VIOLATION>: support_id=5611810483771277404
Oct 26 19:32:00 bigip-01 info tmm[20840]: Rule /Common/irule-asm_blockpage <ASM_RESPONSE_VIOLATION>: web_application=/Common/asm-1
Oct 26 19:32:00 bigip-01 info tmm[20840]: Rule /Common/irule-asm_blockpage <ASM_RESPONSE_VIOLATION>: severity=Error
Oct 26 19:32:00 bigip-01 info tmm[20840]: Rule /Common/irule-asm_blockpage <ASM_RESPONSE_VIOLATION>: attack_type=ATTACK_TYPE_OTHER_APPLICATION_ACTIVITY
Oct 26 19:32:00 bigip-01 info tmm[20840]: Rule /Common/irule-asm_blockpage <ASM_RESPONSE_VIOLATION>: request_status=blocked
once you can confirm ill try to get the cloud docs updated. these things can be made a lot easier when a couple of extra lines explaining the different types of events.
04-Oct-2020 05:03
to be sure you are creating violations right?
different types?
04-Oct-2020 08:01
Yes
I mean I do get the access rejected page, but I get the default page, and I need to customize it.
like described here: https://support.f5.com/csp/article/K22017023
04-Oct-2020 10:57
and you have the irule associated with the virtual server that also has the ASM profile with the "Trigger ASM iRule Events Mode" enabled?
can you add some log statements to your iRule events to see if they get triggered at all?
does the ltm log show something related at the moment?
04-Oct-2020 11:40
Yes It is the same VS.
And yes I tried to add log.local to the iRule but nothing detected at the section of "ASM_REQUEST_BLOCKING"..
09-Oct-2020 00:03
Does anyone has any idea on how to solve this?
10-Oct-2020 00:06
only thing i saw in previous questions is that it didn't trigger for all types of violations, the example there was data guard which didnt trigger it. you might try a couple of different violation types to rule that out.
but if that is ok and if you got a the configuration setup correctly (which you seem to have) and it still doesnt work then it could be a bug, best to have F5 support have a look at your configuration and determine if it is a bug.
10-Oct-2020 01:38
The thing with F5 technical support is tey do not support iRules.
Only in rare cases. or if you have some sort of support level contract ....
10-Oct-2020 01:43
they don't support full debugging / writing of iRules, but they will in my experience assist in something like this or if something clearly fails. specially when you are just following F5 articles and do something relatively simple as this. i would certainly try them.
11-Oct-2020 15:06
Have you tried using ASM_REQUEST_DONE instead of ASM_REQUEST_VIOLATION? ASM_REQUEST_VIOLATION was deprecated in v11.5 and replaced with ASM_REQUEST_DONE.
11-Oct-2020 21:33
If I do that then my website will not be reached and I'll get this browser error message:
This page isn’t working
my.domain.com didn’t send any data.
ERR_EMPTY_RESPONSE
I see the iRule triggered but with errors in /var/log/ltm :
Oct 12 07:30:07 My-F5 info tmm5[14584]: Rule /Common/ASM_custom_block_page_v3 <ASM_REQUEST_DONE>: hello world
Oct 12 07:30:08 My-F5 err tmm5[14584]: 011f0016:3: http_process_state_prepend - Invalid action:0x10a010 Server sends too much data. serverside (172.26.137.34:443 -> 172.26.137.46:6759) clientside (1.2.3.4:62170 -> 172.26.137.41:443) (Server side: vip=/Common/myserver_test profile=http pool=/Common/srv-myserver server_ip=172.26.137.34)
19-Oct-2020 05:08
how is your full iRule looking now?
if you only test with the example from https://clouddocs.f5.com/api/irules/ASM_REQUEST_DONE.html
what happens?
19-Oct-2020 06:01
This is my current iRule
set requri "https://[HTTP::host][HTTP::uri]"
when ASM_REQUEST_DONE {
log local0. "hello world"
#log local0. "Request from [IP::client_addr] blocked: [HTTP::uri]"
set asm_support_id [ASM::support_id]
HTTP::header remove Content-Length
HTTP::header insert header_1 value_1
set client_ip [IP::client_addr]
set response "<html>
<head>
<title>Request Rejected</title>
</head>
<body>
The requested URL was rejected. Please consult with your administrator.<br><br>
Your support ID is: $asm_support_id<br><br><a href='javascript:history.back();'>Go Back</a><br><br>
Your URL is: $requri
Your client IP is: $client_ip
</body>
</html>"
ASM::payload replace 0 0 $response
22-Oct-2020 05:12
so that was an interesting one, took me a few tries to get something working.
the cloud docs suggest that ASM::payload works in most of the ASM events, but for me it only seems to work in ASM_REQUEST_BLOCKING, well certainly the replace only works there.
there is also a known issue which shouldn't be an issue for 14.1 but is for me: https://support.f5.com/csp/article/K13696
so if you set the irule events mode to normal then you use ASM_REQUEST_DONE (instead of the two other ones) but can only check for what happened.
the replacing still has to happen in ASM_REQUEST_BLOCKING.
can you try something like this and show the ltm log output?
log local0. "req done"
switch $i {
when ASM_REQUEST_BLOCKING {
log local0. "req block"
ASM::payload replace 0 0 "abcdefghi"
this is 14.1.2.3 (lab) btw, so things might have changed in 15.1 although i can't find details on that.
25-Oct-2020 23:09
Hi
I launched this iRule and tried to create violation, the ASM blocked me , but the ltm log doesn't show anything related to "req block" log. Here is the output:
Oct 26 08:04:49 My-F5 info tmm2[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: req done
Oct 26 08:04:49 My-F5 info tmm2[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: violation=
Oct 26 08:04:49 My-F5 info tmm2[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: support_id=9864890563438358212
Oct 26 08:04:49 My-F5 info tmm2[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: web_application=/Common/MyServer
Oct 26 08:04:49 My-F5 info tmm2[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: severity=Informational
Oct 26 08:04:49 My-F5 info tmm2[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: source_ip=1.2.3.4
Oct 26 08:04:49 My-F5 info tmm2[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: attack_type=
Oct 26 08:04:49 My-F5 info tmm2[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: request_status=clear
Oct 26 08:04:49 My-F5 info tmm7[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: req done
Oct 26 08:04:49 My-F5 info tmm7[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: violation=
Oct 26 08:04:49 My-F5 info tmm7[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: support_id=9864890563489517902
Oct 26 08:04:49 My-F5 info tmm7[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: web_application=/Common/MyServer
Oct 26 08:04:49 My-F5 info tmm7[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: severity=Informational
Oct 26 08:04:49 My-F5 info tmm7[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: source_ip=1.2.3.4
Oct 26 08:04:49 My-F5 info tmm7[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: attack_type=
Oct 26 08:04:49 My-F5 info tmm7[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: request_status=clear
25-Oct-2020 23:50
because you didnt trigger a violation according to the output. violation is empty and it shouldn't be
yours:
test from me:
Oct 22 13:40:01 bigip-01 info tmm2[20840]: Rule /Common/irule-asm_blockpage <ASM_REQUEST_DONE>: violation=VIOLATION_REQ_LEN,VIOLATION_OBJ_LEN,VIOLATION_OBJ_TYPE
there is no violation information at yours and there should be.
so you have to check if everything is setup correctly, perhaps multiple ASM policies and not having the right one here or ... it is difficult to determine what it could be from a distance.
reaching out to f5 support would be a good idea if you don't see an issue, it might be a bug. im running 14.1 and don't have 15.1 quickly available.
25-Oct-2020 23:54
But I did trigger a violation
I received also a support id and ASM blocked my request
I will try to reach out the support soon
Thanks 🙂
26-Oct-2020 00:38
can you lookup that support id and share the output (redacted where needed)?
26-Oct-2020 00:49
Sure
Attached
26-Oct-2020 10:18
ah interesting, a redirect violation, that might be a reason, as it is in the response.
can you try with another kind of violation?
26-Oct-2020 11:35
switch $i {
logs
28-Oct-2020 07:21
Hi
I tried different violation (illegal file type) and now i can see the req block
Oct 28 16:15:45 My-F5 info tmm1[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: req done
Oct 28 16:15:45 My-F5 info tmm1[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: violation=
Oct 28 16:15:45 My-F5 info tmm1[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: support_id=9864890563816978112
Oct 28 16:15:45 My-F5 info tmm1[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: web_application=/Common/MyServer
Oct 28 16:15:45 My-F5 info tmm1[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: severity=Informational
Oct 28 16:15:45 My-F5 info tmm1[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: source_ip=1.2.3.4
Oct 28 16:15:45 My-F5 info tmm1[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: attack_type=
Oct 28 16:15:45 My-F5 info tmm1[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: request_status=clear
Oct 28 16:15:50 My-F5 info tmm1[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: req done
Oct 28 16:15:50 My-F5 info tmm1[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: violation=VIOLATION_OBJ_TYPE
Oct 28 16:15:50 My-F5 info tmm1[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: support_id=9864890563816985952
Oct 28 16:15:50 My-F5 info tmm1[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: web_application=/Common/MyServer
Oct 28 16:15:50 My-F5 info tmm1[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: severity=Critical
Oct 28 16:15:50 My-F5 info tmm1[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: source_ip=1.2.3.4
Oct 28 16:15:50 My-F5 info tmm1[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: attack_type=ATTACK_TYPE_FORCEFUL_BROWSING
Oct 28 16:15:50 My-F5 info tmm1[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_DONE>: request_status=blocked
Oct 28 16:15:50 My-F5 info tmm1[14584]: Rule /Common/devcentral_irule <ASM_REQUEST_BLOCKING>: req block
04-Nov-2020
06:01
- last edited on
22-Nov-2022
15:12
by
JimmyPackets
Thank you boneyard
This iRule working fine
I just had to add "if support id exist" condition in "ASM_REQUEST_DONE" section
log local0. "hello world1"
set asm_support_id1 [ASM::support_id]
set client_ip1 [IP::client_addr]
set response1 "<html><head><title>Request Rejected</title></head><body>
Your support ID is: $asm_support_id1<br><br><a href='javascript:history.back();'>Go Back</a><br><br>
Your URL is: $requri <br><br>
Your client IP is: $client_ip1
</body></html>"
log local0. "req block1"
ASM::payload replace 0 0 $response1
log local0. "hello world2"
set asm_support_id2 [ASM::support_id]
if {[info exists $asm_support_id2]} {
set client_ip2 [IP::client_addr]
set response2 "<html><head><title>Request Rejected</title></head><body>
Your support ID is: $asm_support_id2<br><br><a href='javascript:history.back();'>Go Back</a><br><br>
Your client IP is: $client_ip2
</body></html>"
log local0. "req block2"
ASM::payload replace 0 0 $response2
This is iRule I took to the next level with ifile and custom html/javascript code
#Created by: AbedB 04-11-2020
#Do not edit this iRule without AbedB permission
set response1 "HTTP::respond 200 content [subst -nocommands -nobackslashes [ifile get "blockpage1.html"]]"
log local0. "req block1 and supportis is: $asm_support_id1"
set response2 "HTTP::respond 200 content [subst -nocommands -nobackslashes [ifile get "blockpage2.html"]]"
