Technical Forum
APM VPE - Group of computers
Jerome_CARRIER
Hello,
I deployed a policy for our VPN via Edge Client. The client check several parameters on the computer and currently, to be able to connect the VPN, the user must be member of a specific Active Directory group. But, is-it possible to change that and not check if user is member of an AD group but check if the computer is member of a specific group ?
BR
1 REPLY 1
boneyard
MVP
MVP
there isn't an easy way, you will have to look up your computername in LDAP, this earlier question shows how to handle that, mainly the sections at the bottom
https://devcentral.f5.com/s/question/0D51T00006i7WjL/ldap-query-for-machine-account
give it a go, if you get stuck let me know, i can give it a try also.
