Roberto_Pulvire's avatar
Roberto_Pulvire
Nov 11, 2021
APM Single Sign-On: Forms - Client Initiated j_security_check issue
I'm trying to use "Single Sign-On: Forms - Client Initiated" to pass the Okta credentials to a web application running on Tomcat.
The web application is returning the following form:
        <form data-empty-path="/APG/empty.html" id="login-form" method="post" action="j_security_check" >
<input type="text" id="username" name="j_username" value="" tabindex="1" placeholder="User Name"/>
<input type="password" id="password" name="j_password" value="" tabindex="2" placeholder="Password"/>
<span class="error-message">
</span>
<button type="submit" tabindex="3" class="ui-button ui-widget ui-state-default ui-state-disabled ui-corner-all ui-button-text-only"><span class="ui-button-text">Login</span></button>
</form>
My Form Definition settings are the following:
- name = insightful_java
- Detect request for form by: "URI" with Request URI: "/APG"
- Identify Form by: Form Parameters with j_username=%{session.sso.token.last.username} and j_password=%{session.sso.token.last.password}
- Disable Auto detect submit = No
- Detect Login by = None
- Javascript Injection = Auto
Under these conditions I see that the form is not automatically filled in the /APG/j_security_check?f5-sso-form: insightful_java sent by my browser.
Or better, I can see that the request is sent with query string parameter = "f5-sso-form: insightful_java", but the "Form Data" is empty
My understanding is that the auto generated javascript code used with this setup is the following:
<script>
document.body.onkeydown=function(e){return false;};
document.body.style.visibility='hidden';
document.body.style.display='none';
function __f5submit() {
  var __f5form = document.forms[0];
  __f5form.setAttribute('autocomplete', 'off');
  __f5form['j_username'].value='giv';
  __f5form['j_password'].value='f5-sso-token';
  var __f5action = __f5form.action;
  var __f5qsep = (__f5action.indexOf('?') == -1) ? '?' : '&';
  __f5form.action = __f5action + __f5qsep + 'f5-sso-form=insightful_java';
  __f5form.submit();
if (window.addEventListener) {
 window.addEventListener('load',__f5submit,false);
} else if (window.attachEvent) {
 window.attachEvent('onload',__f5submit);
 window.onload=__f5submit;
</script>
Can you please help me to address this issue?
Thanks.
Roberto
