17-Apr-2023 16:44
14.1.5.2 with APM
Hi, we have APM confiugred presenting native rdp to users. we have serval hundred users using this on a daily basis without issue, but we now have 3 users who cannot launch the rdp session and get a windows error popup "Remote resource cannot be reached". We know its related to the workstation because that same user can use a different workstation with their same accoutn and it will work.
When I packet cap on the F5 I do not see the trfafic hit the F5, so again 100% a windows issue rather than F5, but wondering if anyone came across this and know a solution? remote desktop works fine for them to other local servers etc, I cannot see anythign in eventviewer that would indicate why its failing, the cert installed on APM is a CA signed valid cert. An activeX rdp icon does work for them, but its difficult to use since it requires a few browser hacks.
Any help would be great
Solved! Go to Solution.
27-Apr-2023 15:28
Found out it was related to registry string: RDGClientTransport
if its not present or set to 0 (which is default) it will work. if its set to 1 or 2 it will fail with that error.
19-Apr-2023 05:03
If you catch the RDP file served from APM does it look right, especially the gateway configuration?
19-Apr-2023 13:57
Yes the contents are identical to the rdp file on my machine which works
19-Apr-2023 22:17
My next step would be to validate if any packages are leaving the machine with Wireshark.
If that isn't the case I think it must be related to application firewalling (or what it is called on Windows 😀) which stop the traffic from going out.
27-Apr-2023 15:28
27-Apr-2023 22:16
Fantastic! 😁
Do you have any documentation of this setting?
It sounds interessting.
28-Apr-2023 01:00
Just what I found on google:
The Remote Desktop Protocol v8 introduced the HTTP & UDP transports. The values for the RDGClientTransport registry key are;
