Technical Forum
APM portal access with iframe
Abdullah
hi experts,
i have issue with APM portal access. i using APM as landing page for SharePoint portal and its working fine the issue start once i open another page inside the share point portal that use iframe. once i click on it the content dose not appears and return time out error. I tried to use the rewrite with no luck.
your support are highly appreciated.
0 REPLIES 0
